Just wanted to inform the users ready to install new 2016 products to remove or turn of the following servers (Application: Connect.Service.ContentService.exe).
In my event log I get this error every minute and my mouse keeps jumping off the current window once I stopped the service the problem did go away.
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
Stack:
at System.Data.SqlServerCe.SqlCeException.ToString()
at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
or
Faulting application name: Connect.Service.ContentService.exe, version: 20.1.49.0, time stamp: 0x54d43c57
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x000007fe90d06887
Faulting process id: 0x1398
Faulting application start time: 0x01d0a3776400ad58
Faulting application path: C:\Program Files\Autodesk\Content Service\Connect.Service.ContentService.exe
Faulting module path: unknown
Report Id: a1d5af9c-0f6a-11e5-9586-b8ca3aa5f14e
Thanks for the URL,
Just installed both.
Now, to see if it works over time.
RC
