AutoCAD Forum
Missing .shx to open .dxf
12 REPLIES 12
Message 1 of 13
1760 Views, 12 Replies
Hello all!
I am unable to open a .dxf in AutoCAD 2017 because its looking for a missing cvltshp.shx. I've searched for this file with no success. Is there anyway I can bypass this? its not giving me a prompt to ignore...it wants me to point it to where the file is located. Thanks for any help provided.
12 REPLIES 12
Message 2 of 13
Alfred.NESWADBA
Should not be a problem, can you upload this DXF-file so we can try that?
What happens if you show another SHX-file (e.g. TXT.SHX) ... it may show the fonts differently or miss some linetypes, but the drawing should continue to open.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 13
in reply to: Alfred.NESWADBA
Thanks for the reply Alfred. Attached is the dxf thats giving me issues. I will try to point it to another file but its specifically asking for the file mentioned above.
When I tried to point it to txt.shx, and any other .shx for that matter, it gave me the following error message: "xxxx.shx is a normal text font file, not a shape file."
Message 4 of 13
Alfred.NESWADBA
please try the attached DXF, I only removed the style definition and the DXF loaded fine (but without warranty about the content!)
- alfred -
Alfred NESWADBA
Message 5 of 13
That did the trick Alfred! I have 6 other sheets to this drawing...would you be willing to help me out with the rest?
Message 6 of 13
Alfred.NESWADBA
I see only 3 files in your post...
(if you ZIP them all together the upload is much faster)
- alfred -
Alfred NESWADBA
Message 7 of 13
I knew that...lol. Must be the excitement of finally getting this resolved. you work much faster than our IT.
Message 8 of 13
there are sht 1 to 3
- alfred -
Alfred NESWADBA
Message 9 of 13
Alfred.NESWADBA
are the first three files in your ZIP different to the first 3 files you already uploaded?
- alfred -
Alfred NESWADBA
Message 10 of 13
No, they are the same.
Message 11 of 13
Alfred.NESWADBA
now the ZIP with sht 4-7
ATTENTION: sht5 was defect (had another DXF error besides of the missing SHX), so I had to run some repair steps, not sure if that is really complete!
- alfred -
Alfred NESWADBA
Message 12 of 13
Sheet 5 looks complete enough. Thanks so much! You're a life saver.
Message 13 of 13
Alfred.NESWADBA
You are very welcome, glad I could help!
- alfred -
Alfred NESWADBA
State of Sustainability Webinar
AutoCAD Inside the Factory
