I researched and could find only similar, not exact.
All toolbars missing and menu missing.
I can not access 'reset default settings'. Opening AutoCAD, the only two
tabs that show are 'File' and 'Edit.
When I click on 'Autodesk' for AutoCAD, I do not get the options.
The toolbars and all were okay, but they just did not appared when I recently
opened the program.
Options?
Thank you
jim
Hi @Anonymous,
What version of AutoCAD are you using and on which operating system?
It sounds like the menus have just been unloaded and a reset is likely the easiest way to bring everything back to normal. You should be able to browse in Windows Explorer to fine the Reset Settings to Default.
Mine is stored here for 2016:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\AutoCAD LT 2016 - English
i'm afraid that you launch AutoCAD from a new windows user ( not the user that autocad installed from ) .
Imad Habash
Hi @Anonymous,
Did you really mean AutoCAD 2007? Or, did you mean 2017? I found this video on YouTube that shows how to load the menus in AutoCAD 2006 which should be similar in 2007.
HI
PRESS CTRL+0 to off the clean screen.
IF NOT WORK, PLEASE FOLLOW BELOW PROCEDURE.
1. For Menu Bar
Click Arrow of Quick access Tool Bar and select Show Menu bar
2. FOR RIBBON TOOL BAR
just type RIBBON in Command
3. FOR COMMAND LINE
just press CTRL+9
4. FOR ANOTHER ALL TOOLBAR
goto Tools (from Menu bar) --> TOOL BAR --> AUTOCAD --> ( YOU WILL GET MOST USING TOOLS LIKE DRAW TOOL, MODIFY TOOL)
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hi @dustwitch,
I suggest that you look to see which Windows updates or hardware drivers just got updated. If you can isolate it to a single update, please uninstall it to see if that returns the functionality.
yes, this solved MY problem! i had accidentally pressed CTRL+0 and "cleaned" my screen! thanks so much -- that solved my problem!
On my acadR14 it can't find acad.mnc, acad.mns and acad.mnu when they are clearly in the support folder and the path is correct.
