AutoCAD Forum
Missing Menu's, tool bars and everything!
11 REPLIES 11
Message 1 of 12
21965 Views, 11 Replies
I researched and could find only similar, not exact.
All toolbars missing and menu missing.
I can not access 'reset default settings'. Opening AutoCAD, the only  two
tabs that show are 'File' and 'Edit.
When I click on 'Autodesk' for AutoCAD, I do not get the options.
The toolbars and all were okay, but they just did not appared when I recently
opened the program.
Options?
Thank you
jim
11 REPLIES 11
Message 2 of 12
john.vellek
Hi @Anonymous,
What version of AutoCAD are you using and on which operating system?
It sounds like the menus have just been unloaded and a reset is likely the easiest way to bring everything back to normal. You should be able to browse in Windows Explorer to fine the Reset Settings to Default.
Mine is stored here for 2016:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\AutoCAD LT 2016 - English
John Vellek
Message 3 of 12
imadHabash
i'm afraid that you launch AutoCAD from a new windows user ( not the user that autocad installed from ) .
Message 4 of 12
in reply to: imadHabash
Thank you.
May I add that when I opened the program, AutoCAd2007, where the block
pops up that shows the list of workshops on the left side, there were no
workshops listed. I was unable to 'X' out of this and I was only allowed to
click on 'OK'. I clicked on 'OK', the AutoCAD screen came up, and this was
when no toolbars showed.
Anything to comment?
Thank you,
jim
Message 5 of 12
john.vellek
Hi @Anonymous,
Did you really mean AutoCAD 2007? Or, did you mean 2017?  I found this video on YouTube that shows how to load the menus in AutoCAD 2006 which should be similar in 2007.
John Vellek
Message 6 of 12
HI
PRESS CTRL+0  to off the clean screen.
IF NOT WORK, PLEASE FOLLOW BELOW PROCEDURE.
1. For Menu Bar
Click Arrow of Quick access Tool Bar and select Show Menu bar
2. FOR RIBBON TOOL BAR
just type RIBBON in Command
3. FOR COMMAND LINE
just press CTRL+9
4. FOR ANOTHER ALL TOOLBAR
goto Tools (from Menu bar) --> TOOL BAR --> AUTOCAD --> ( YOU WILL GET MOST USING TOOLS LIKE DRAW TOOL, MODIFY TOOL)
Message 7 of 12
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 8 of 12
dustwitch
This just happened to me today as well and on Monday it happened with another co-worker. We both just started using 2018 within the last week, but going back to 2016 for older jobs. I don't know if something is causing a conflict or what.
Message 9 of 12
john.vellek
in reply to: dustwitch
Hi @dustwitch,
I suggest that you look to see which Windows  updates or hardware drivers just got updated. If you can isolate it to a single update, please uninstall it to see if that returns the functionality.
John Vellek
Message 10 of 12
in reply to: john.vellek
I had to uninstall and re-install the program. Thanks
Message 11 of 12
yes, this solved MY problem! i had accidentally pressed CTRL+0 and "cleaned" my screen!  thanks so much -- that solved my problem!
Message 12 of 12
whitefang1953
On my acadR14 it can't find acad.mnc, acad.mns and acad.mnu when they are clearly in the support folder and the path is correct.
Technology Administrators
