AutoCAD Forum
Line Color does not reflect layer color
11 REPLIES 11
Message 1 of 12
34906 Views, 11 Replies
Hello All
I'm using AutoCAD 2013 and no matter what I do my Line color always comes up green even
when the current layer color is red. I have to keep going back to proprieties and change line color
to red. Any advice would be helpful.
Dave
Northern California
11 REPLIES 11
Message 2 of 12
jayhar
Find the attachments........
  1. May be your ACAD selection Green is Default.
  2. Check pen assignment, this option only you can see in layout.
please upload your cad file...............
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 12
Vinayv4v
Hi, Enter command COLOR and make sure it is set to BY LAYER format.
Check what is the value of system variable SETBYLAYERMODE. Default value is <255>.
Cheers,
Vinay Vijayakumaran
Message 4 of 12
ian.mag
Hey,
1. Select the line with this property.
2. Right click and select similar.
3. If the properties tool isn't already opened, open it by typing PROPS.
4. Change the layer to be By Layer.
This should solve your issue.
In the home tab, in the properties panel, change the color to be By Layer as well
Message 5 of 12
pendean
AutoCAD2013 is not new by any means: -versions old now.
So what changed recently with your setup?
Or is the problem just in this one DWG file?
Tell us more.
Message 6 of 12
in reply to: pendean
Hi Thanks for getting back so quickly.
I have the problem fixed.
Message 7 of 12
scot-65
Lots of good replies here except for those that use the keyboard...
Command: CECOLOR
Enter new value for CECOLOR <"BYLAYER">:
The same goes for CELTSCALE, CELTYPE, CELWEIGHT as well as hatches (HPCOLOR)...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 8 of 12
in reply to: Vinayv4v
Thx this works!
Message 9 of 12
Oh my god. . .!! Thank you sir! You are awesome for posting.
Message 10 of 12
in reply to: scot-65
CECOLOR WAS THE CORRECT ANSWER AND SOLVE THE PROBLEM FOR ME. THANKS. MATT
Message 11 of 12
Cad4fish
I have tried both COLOR and CECOLOR and neither had the color of this array to match the layer.  Other arrays in other locations in the same drawing had the correct color.
Message 12 of 12
None of the above solutions worked for me. Then I figured out all of the ones I had issues with were Block References. Solution there is to edit each block with the block editor and make sure all the parts of the block are layer "0", then each instance of the block will take on the ByLayer color if assigned.
Forma Design Contest
