AutoCAD Forum
Leader - underline top line length
5 REPLIES 5
lenka8D4N2
1422 Views, 5 Replies
I have a multileader style set on the "underline top line" option. The underline goes to the end of the whole text rather than the length of just the top line - see picture. Is there a way how to underline just the top line (the red line in the picture)?
I've attached even my settings for the leader style - I though that the option "Extend leader to text" on the "Content" tab should be solving this but nothing changes if it's ticked or not...
Do you have any idea what is the problem?
Thanks a lot!
Labels (1)
5 REPLIES 5
ennujozlagam
in reply to: lenka8D4N2
try to change line space style to exactly and see if helps. thanks
imadHabash
i doubt that it could be fixed as you asked , this is how it's work !!
Imad Habash
lenka8D4N2
in reply to: ennujozlagam
Thanks for quick response. It didn't help unfortunately.
vinodkl
Sorry. That's how it works. The length of the leader under the text varies based on the text width factor, so as the width of the text increases the leader line also increases based on that.
You can try this:
set the left/right attachment to "bottom of top-line" and then underline the top line from mtext editor as shown in the snapshot.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
lenka8D4N2
in reply to: vinodkl
Thank you for reply, this solution has crossed my mind too but it looks rather messy than nice :/. Thanks anyway.
Forma Design Contest
AutoCAD Beta
