I have a multileader style set on the "underline top line" option. The underline goes to the end of the whole text rather than the length of just the top line - see picture. Is there a way how to underline just the top line (the red line in the picture)?
I've attached even my settings for the leader style - I though that the option "Extend leader to text" on the "Content" tab should be solving this but nothing changes if it's ticked or not...
Do you have any idea what is the problem?
Thanks a lot!
try to change line space style to exactly and see if helps. thanks
i doubt that it could be fixed as you asked , this is how it's work !!
Imad Habash
Sorry. That's how it works. The length of the leader under the text varies based on the text width factor, so as the width of the text increases the leader line also increases based on that.
You can try this:
set the left/right attachment to "bottom of top-line" and then underline the top line from mtext editor as shown in the snapshot.
Thank you for reply, this solution has crossed my mind too but it looks rather messy than nice :/. Thanks anyway.
