AutoCAD Forum
Layout shifted in PDF
8 REPLIES 8
Message 1 of 9
688 Views, 8 Replies
When I plot a layout with conceptual style to a PDF, it appears in 2 separate images. Those images are both separate clickable and copyable. But the problem is that the 2 images are shifted and not perfectly lined out.
8 REPLIES 8
Message 2 of 9
pendean
if you zoom in the PDF viewer you are using, does that shift in graphics disappear?
Message 3 of 9
in reply to: pendean
No, it's still there. Even when I print the PDF it's shifted.
Message 4 of 9
pendean
Post your PDF and the source DWG file for everyone to have a look at your content please.
Message 5 of 9
Here they are. I hope you can find something
Message 6 of 9
pendean
Do you have the 2020.1.3 update installed yet? ABOUT command will confirm: see attached test from my R2020 PUBLISH command, I don't see the jog here.
Message 7 of 9
Is it possible that it has something to do with plotting to PDF? With settings do you use?
Message 8 of 9
I use Autocad 2020.1.3 indeed
Message 9 of 9
pendean
I simply used PUBLISH command with the DWG TO PDF option to create the PDF I posted here.
Forma Design Contest
AutoCAD Beta
