Plot file name
Plot file name
sports7
Plot file name
sports7
When i plot to PDF it shows the dwg name and the tab name.  How can i get it to only show the dwg name.
Example below dwg name is C-2704 and tab name is Master so i get C-2704-Master in the file name.
CADmgrMike
Need to know what PDF driver you're using.
Are you printing directly in the sheet, or printing from Sheet Set Manager?
My experience is if using the OOTB Autocad DWGtoPDF driver and you print directly from the sheet, the layout shows up in the name and haven't figured out how to change that.
If you print your drawings from Sheet Set Manager and use the same driver, it will leave the layout name off and only use the sheet number and title.
Mike Porter
https://provostandpritchard.com/
