I am having issues with assigning a line to a certain layer. When I go to change it from the layer menu, nothing changes. The line stays white with no assigned layer. The only way I can change the layers now is by opening up properties and changing them manually from there. The only connection that may have caused this is I had a computer guy come last week to fix my graphics card. I got the newest version installed of NVIDIA GeForce GTX 1060. This started happening around the same time. I can't remember if it was before or after. I believe it was before though.
Solved by user181. Go to Solution.
>>" assigning a line to a certain layer. When I go to change it from the layer menu,"
What do you mean with "layer menu" ?
LAYERproperties manager?
You can not change objects by using this palette.
Toolbar combi item?
Check your PICKFIRST setting
Or by a ribbon combi item?
Check your PROPOBJLIMIT
Sebastian
