Hyperlink to another DWG minimizes Window.
cbenner
Mentor Mentor
Message 1 of 25
cbenner
I've seen several posts over the years similar to this, but haven't really found any answers.
I'm messing with cross drawing hyperlinks for the first time.  I like the way they work, but when you ctrl-click to use one, as soon as the linked drawing opens the AutoCAD window minimizes.  I'm posting a screencast of this.
Any ideas why this happens or how to stop it from happening?
Replies (24)
Message 2 of 25
john.vellek
Hi @cbenner,
I am curious about the error message you are seeing.
It appears that you have some stuff either loading from our Startup Suite or from a Lisp routine. and that it needs some information.
Try logging in as a new user (no customization or migration) and see if this behavior goes away.
John Vellek
Message 3 of 25
cbenner
@john.vellek
John,  what you are seeing is my own customization.  This is a popup to remind users that they need to run a specific utility before they start a dropping lines into a new P&ID.  Should not have anything to do with this hyperlink behavior.
Message 4 of 25
JTBWorld
I can reproduce this unexpected behavior when you start with having AutoCAD maximized, then AutoCAD gets restored down like if you had clicked on the restore down button next to X at top right. Sure is a bug. Workaround is to resize AutoCAD to the full screen but not have it maximized.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 5 of 25
cbenner
Message 6 of 25
john.vellek
Hi @cbenner,
I am about to log this for QA to examine.  The video shows the behavior in 2017 so I have verified that this occurs in AutoCAD 2017, 2018, and 2019.
Thank you for bringing this to my attention.
John Vellek
Message 8 of 25
JTBWorld
I could reproduce it i and AutoCAD 2019 using these steps. Draw a circle, add hyperlink to it to another drawing, make sure AutoCAD is maximized, follow the hyperlink.
Jimmy Bergmark
Message 9 of 25
JTBWorld
I've reproduced this is AutoCAD 2019. Just add a hyperlink to another drawing on any object and try it in maximized window mode.
Update: This is a duplicate message due to the long delay when replying via email. I thought it didn't work so I replied online too.
Jimmy Bergmark
Message 10 of 25
charles.lauricello
Did anyone ever solve this?  Its annoying!!!!!!
Message 11 of 25
Has it been solved?  Like to know as well.
Message 12 of 25
pendean
Community Legend
Community Legend
Start a Support Ticket at your account login https://knowledge.autodesk.com/contact-support
Message 13 of 25
DJGinAZ
I'm still getting this behavior on 2023. Bummer. It was "intentional" behavior in 2016.
Clicking on an entity with a hyperlink minimizes AutoCAD.
Message 14 of 25
JBerns
Is this a Windows bug or an AutoCAD bug?
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 15 of 25
CGBenner
@JBerns
Hi Jerry... I had forgotten all about this one since I don't do anything in AutoCAD anymore.  From what I could see it was an AutoCAD related bug.  The Acad team person who initially responded to me is no longer here, so I hope someone else can take up the discussion for you folks who are still dealing with this.
Chris Benner
Message 16 of 25
DJGinAZ
This bug was similar to the one that would fully minimize ACAD when a Web Link was clicked (Google Maps for example)
I can confirm that 2025 versions have fixed the bug that minimizes ACAD when following Web links, although I'm not certain if it's the same bug as following a link to another DWG.
Message 17 of 25
CodeDing
If you're into some customization, my Perfect Preview command might be more useful for previewing/accessing hyperlinks.
Hoping to add support for viewing DWG files in the future.
View in this post here:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/perfect-preview-hyperlinks-are-under...
Best,
~DD
Message 18 of 25
apjones
This bug appears to still exist in ACAD 2025.  I can duplicate this with or without any customization.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 20 of 25
CGBenner
@JBerns
Jerry, do you still need help with this?
Chris Benner
