How to calculate the total length of multiple lines
veloster
Message 1 of 77
veloster
Hi!
I would like to know if it's possible to have the total length of different lines by selecting them in a drawing?
Those lines are all separated and it will take forever to do it manually on a calculator 🙂
Thx!
Replies (76)
Message 2 of 77
nestly2
Welcome to the Autodesk forums.
AutoCAD doesn't have anything like that built in, but it's easily done with TLEN.lsp (Total LENgth of selected objects)
http://www.turvill.com/t2/free_stuff/tlen.lsp
If you're not familiar with how to use lisp, simply copy/paste (CTRL+V) ALL the text and characters in the above link into your command line and press Enter, then type TLEN into the command line and follow the command prompt (select the objects)  Note using this method, the lisp is only loaded for the current session, if you want it to be a permanent feature, Add it to the Startup Suite or the acaddoc.lsp file.
Message 3 of 77
veloster
Thanks! Works perfectly!
Message 4 of 77
Kent1Cooper
There are several additional routines that will do that here.
Kent Cooper, AIA
Message 5 of 77
braudpat
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
I am using since a long time ago this nice French routine : TLENGTH
which is running on : LINE , POLYLINE , LWPOLYLINE , ARC , CIRCLE , ELLIPSE , SPLINE , MLINE , REGION , MPOLYGON
You can remove easily some entities from the filter inside the routine ...
Thks to Patrick_35 for this beautiful routine ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 6 of 77
ajahmadi
working better than what I expected.
Message 7 of 77
There's "MeteorSpec" plug-in that calculates the summarized lengths of polylines.  Look at Autodesk Exchange apps.
https://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com:meteorspect...
Message 8 of 77
thats perfect
Message 9 of 77
How do you Add it to the Startup Suite or the acaddoc.lsp file?
Message 10 of 77
Patchy
Appload command, and look for the suitcase icon, add it in there.
Message 11 of 77
Thanks for the help. Worked great.
Message 12 of 77
when i select the lines and press enter nothing happens.help..
Message 13 of 77
the command is not working for me.when select the lines and press enter nothing happens.any idea why?my cad is not the full version.not activated.mayb thas y?
Message 14 of 77
Kent1Cooper
@Anonymous wrote:
....my cad is not the full version....mayb thas y?
If by that you mean you are using AutoCAD LT, that would be the reason.  It does not have AutoLisp capability.
Kent Cooper, AIA
Message 15 of 77
yosephk
Click Analyze tab,Inquiry panel,Add Distances.
Windows 10 Pro x 64
16 GB Ram
Intel Xeon E3-1220 V2 @ 3.1 GHz
NVIDIA Quadro 600
Civil 3D 2019
Message 16 of 77
thank, it works very nice..............
Message 17 of 77
Well done it woks very well. Cheers
Message 18 of 77
Thank you. Just what I needed.
Message 19 of 77
Very nice thank you so much..
Message 20 of 77
wisedrawing
for accumulative lengths by picking points along the way:
Just searched this little gem out:
TLENGTH - PICK FIRST POINT - THEN SELECT MULTIPLE AND CLICK AWAY - RIGHT CLICK TO END = TOTAL LENGTH
this is brilliant - no lisp or other complex workarounds
well done Pat
Darren
