How to calculate the total length of multiple lines
veloster
Message 1 of 78
veloster
Hi!
I would like to know if it's possible to have the total length of different lines by selecting them in a drawing?
Those lines are all separated and it will take forever to do it manually on a calculator 🙂
Thx!
Replies (77)
Message 61 of 78
Kent1Cooper
@israel.shawEKTNS wrote:
There are some errors with the .lsp. It was able to work well for most of the polylines in my drawing. But for some, it returns a value of 0. The length shows up in the properties panel the same way as the other polylines, but the app doesn't seem to see these ones.
Are any closed Polylines?  If so, one way of getting their length with (vlax-curve-...) functions returns zero, but there's another way that doesn't.  Which code out of sixty-some Messages and links are you using?
Kent Cooper, AIA
Message 62 of 78
israel.shawEKTNS
I was using the tlenght by braudpat in message 5. But it turns out the ones that weren't working were 2D polylines. It's an easy conversion, so I'm good now. But it's worth noting the lsp doesn't work for 2D polylines
Message 63 of 78
Kent1Cooper
It just left out the term for those.  But a lot of them can be combined into the same length determination.  You can change this much:
((member (vla-get-objectname ent) '("AcDbLine" "AcDb3dPolyline" "AcDbPolyline"))
(setq di (+ di (vla-get-length ent)))
((eq (vla-get-objectname ent) "AcDbArc")
(setq di (+ di (vla-get-arclength ent)))
((eq (vla-get-objectname ent) "AcDbCircle")
(setq di (+ di (vla-get-circumference ent)))
((member (vla-get-objectname ent) '("AcDbSpline" "AcDbEllipse"))
(setq di (+ di (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent))))
to just this:
  '("AcDbLine" "AcDb3dPolyline" "AcDb2dPolyline" "AcDbPolyline"
    "AcDbArc" "AcDbCircle" "AcDbSpline" "AcDbEllipse"))
Or:
((wcmatch (substr (vla-get-objectname ent) 5)
  "Line,3dPolyline,2dPolyline,Polyline,Arc,Circle,Spline,Ellipse")
Kent Cooper, AIA
Message 64 of 78
CADDVV
Good to know, thank you!
Message 65 of 78
braudpat
Hello@Kent1Cooper
Thanks for the improvment !
Happy New Year, The Health, Bye, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 66 of 78
jebinabraham
Select  the lines and enter DATAEXTRACTION, then window pops up. Select create new data extraction and click next. Enter file name for a new file n save it in your preferred location. Then click save and in next window select object in the current drawing and click the boton on right to it. Select the lines in your drawing. Click next. Click next again. On right in category unchecked all except geometry. In the left side unchecked all except length. Click next. Click next again. Select output data to. Xls. Select location n file name and it will b saved in excel file. Open that excel file n add all the lengths.
Message 67 of 78
james1973622103
exactly what I'm looking for, Thanks you!
Message 68 of 78
kmatsuoka
Observer
Observer
Thank you. this is a great way
Message 69 of 78
CADDVV
Can you repost the lisp?  The link does not work or has been removed.
Thanks!!
Message 70 of 78
CADDVV
Is it possible to resend the link with the lisp? When I tried to use the link it no longer worked.
http://www.turvill.com/t2/free_stuff/tlen.lsp
Message 71 of 78
pendean
Community Legend
Community Legend
Thanks!!
https://www.google.com/search?q=tlen.lsp
Message 72 of 78
muhammad_tahirSA3UH
Community Visitor
Community Visitor
Thanks mate.
Message 73 of 78
OmniCardoso
Hey there, I just downloaded this and when I run it, it says "The Total Length of the xx objects are : 0.000"
Any tips on why it's not working?
Message 74 of 78
braudpat
Hello @OmniCardoso
Please use this version of the LENGTH routine !
Patrice BRAUD
Message 75 of 78
ealexanderK6PT2
Observer
Observer
This should be bumped up to the #1 solution. I'm not anti LISP routine or anything but I feel like this solution will help people become better CAD users and not just solve a calculation problem.
Message 76 of 78
sambathdesignerT7GCN
Community Visitor
Community Visitor
Dear sir
I had downloaded but I don't know how to install or where to copy to,
This the file name that I got, AntoniaPetrovaTotalLength.msi
Could you please give me the guide line,
Sambath
Message 77 of 78
muhammad_tahirSA3UH
Community Visitor
Community Visitor
Download the totallength lisp command from google.
Load it in your CAD and run it.
Message 78 of 78
Type command MEASUREGEOM. If your CAD version has this command then simply type T (total lenght) and then select objects with polygon. Result shall be shown in command line. Works for all types of lines.
