AutoCAD Forum
How to join two straight MLine (Multiline)?
4 REPLIES 4
Ali.Katebi
2856 Views, 4 Replies
Hi everyone
I wanna draw walls with MLine (Multiline), I have a problem with straight walls with two different widths (like the image sent).
Also, I couldn't join them to each other with any of the commands at the MLEdit window.
Best Regards
Tags (2)
Labels (1)
4 REPLIES 4
imadHabash
in reply to: Ali.Katebi
Sorry ... It's NOT applicable .
Imad Habash
j.palmeL29YX
Is this what you're looking for?
If yes, try >>this<<
And/or if you want to "connect/join" the MLines, you can create a group or a block. (I don't know your final goal).
Two additional short lines let you get this:
Do you really need MLines? Perhaps you can draw better a Polyline with different Width for each segment?
Jürgen Palme
Ali.Katebi
in reply to: imadHabash
Unfortunately, I think so...
Ali.Katebi
in reply to: j.palmeL29YX
Thank you so much, but this method may be used for a small part of the project, but it is unusable for a complete project. I think this tool is flawed just because of this problem.
Forma Design Contest
AutoCAD Beta
