Hi everyone
I wanna draw walls with MLine (Multiline), I have a problem with straight walls with two different widths (like the image sent).
Also, I couldn't join them to each other with any of the commands at the MLEdit window.
Best Regards
Solved by imadHabash. Go to Solution.
Is this what you're looking for?
If yes, try >>this<<.
And/or if you want to "connect/join" the MLines, you can create a group or a block. (I don't know your final goal).
Two additional short lines let you get this:
Do you really need MLines? Perhaps you can draw better a Polyline with different Width for each segment?
Jürgen Palme
