AutoCAD Forum
How to display the center line so that the strokes are always symmetrical?
9 REPLIES 9
Message 1 of 10
blackriver9
1278 Views, 9 Replies
I'v received a dwg file from a company. In the drawing, the strokes or line segments of the center line and hidden lines are always symmetrical, no matter what the length is.
Does anyone know how to do it? Thanks in advance.
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
blackriver9
in reply to: blackriver9
Attach a png file to make this question more clear
Message 3 of 10
can you please upload this dwg-file?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 4 of 10
imadHabash
Would you please attache here a screenshot or a CAD dwg file to see what you're talking about ?
Imad Habash
Message 5 of 10
Kent1Cooper
That's the way AutoCAD draws them.  Are they not coming out that way for you?
If you're talking about Polylines, and the difference between something like these:
[assymmetrical on the left, symmetrical on the right], that's controlled by the LINETYPE GENERATION setting.  To always draw them symmetrically, set the PLINEGEN System Variable to 0.  For one already drawn, select it and look at the bottom of the Properties palette for the Linetype Generation slot, and disable it.
Kent Cooper, AIA
Message 6 of 10
Kent1Cooper
in reply to: Kent1Cooper
@Kent1Cooper wrote:
.... If you're talking about Polylines....
[... or, another way to make their dash-gap-dot patterns symmetrical, if you can bring yourself to do it, but that I don't recommend, is to EXPLODE the Polylines.  One reason not to, that won't apply in all cases, is that they would lose any width(s).]
Kent Cooper, AIA
Message 7 of 10
GrantsPirate
You will need to load linetypes and apply them to a layer.  See attached screencast.  Is this what you were after?
https://autode.sk/3vaJ4dX
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 8 of 10
blackriver9
@Alfred.NESWADBA @imadHabash The attached linetype.dwg file shows the symmetry of the centerline strokes, no matter how you drag an endpoint, it can be maintained.
@Kent1Cooper @GrantsPirate Symmetrical display of strokes does not seem to be the default. The entities in the attached file not_symmetric.dwg are copied from linetype.dwg, but the strokes of the centerlines are not symmetrical.
Message 9 of 10
imadHabash
Thanks for your attached drawing samples .... Both of your drawings has a different settings , but are not limited to, the following :
  • one of them use metric units and the other use Imperial units . >> Click <<
  • depending on the above point ...  Linetypes are defined in a linetype definition (LIN) file. When you load a linetype, you select the linetype definition file and a specific linetype from within that file. Two linetype definition files are available: acad.lin for imperial units, and acadiso.lin for metric units.
  • LTSCALE ( System variable ) for both drawings are different .
  • also from UNITS command you will find differences .
for that you have to make sure when you start a new drawing what kind of settings you have in your drawing to get a good results and to avoid such a problem as you have .
Imad Habash
Message 10 of 10
blackriver9
Thank you everyone, I know why. The center line data was generated by a program. If the center line data is reloaded in the Autocad interface, the center line strokes are always displayed symmetrically. As for why the centerline data generated by this program can not always display the centerline strokes symmetrically, it is not clear.
Forma Design Contest
AutoCAD Beta
