The card of the template I-Arch have some descriptions to fill that i dont know what to put in! i need someone to explain me how to complete it!
This is for my final project!
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Your Titleblock information looks fine. The other fields for information would apply if this was a commercial project. Typically each project is assigned a name and number. Issue dates and revision dates help to track the changes to the project until it is completed. General notes are notes for fabrication or construction.
I hope this helps. Nice looking project.
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
