dear all,
i have one doubt, i make the drawing in meters if i take the dimension (measurements) that one showing in millimeters. how to change into dimension in meters??
please any one help me to find a solution. herewith i attached the pic..
Solved by jayhar. Go to Solution.
Solved by alex101000. Go to Solution.
or
MY SCALE FACTOR AND ALL THINGS ARE CORRECT.. I NEED TO CHANGE MILLIMETER TO METER IN DIMENSION..
Please show a screenshot of the dimension style settings.
IF I CHANGE THE MEASUREMENT SCALE INTO 1.0000. IN DRAWING METERS ONLY SHOWING EXAMPLE AS PER DRAWING LENGTH IS (373.892Meters) but after i am changing the measurement scale is showing only (373 Meter) then what is the correct standard measurement scale?
The problem is, one acad drawing unit can be any unit you wish it to be, e.g. 1 acad unit = 1mm, or 1 acad unit = 1 ft.
You can change Scale factor in dimension style or selecting dimension go to properties below primary units Dim scale linear see the video.
or
https://knowledge.autodesk.com/community/screencast/18000cbb-dae5-46f8-938a-18ea9bb7978e
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
If you take a look at the circled label on the dialog screen shot, it says:
"Units to scale inserted content" (emphasis on inserted)
It means what it says - if the inserted content (i.e. blocks) has units, rescale it by the appropriate factor to show in meters.
