how to change mm to meter??
Message 1 of 8
dear all,
           i have one doubt, i make the drawing in meters if i take the dimension  (measurements) that one showing in millimeters. how to change into dimension in meters??
please any one help me to find a solution. herewith  i attached the pic..mm.JPG
Replies (7)
Message 2 of 8
alex101000
Use correct measurment
or
Realy convert
Message 3 of 8
MY SCALE FACTOR AND ALL THINGS ARE CORRECT.. I NEED TO CHANGE MILLIMETER TO METER IN DIMENSION..
Message 4 of 8
alex101000
Please show a screenshot of the dimension style settings.
Message 5 of 8
IF I CHANGE THE MEASUREMENT SCALE INTO 1.0000. IN DRAWING METERS ONLY SHOWING EXAMPLE AS PER DRAWING LENGTH IS (373.892Meters) but after i am changing the measurement scale is showing only (373 Meter)                    then what is the correct standard measurement scale?
Message 6 of 8
alex101000
About Units of Measurement
To Specify the Drawing Units
The problem is, one acad drawing unit can be any unit you wish it to be, e.g. 1 acad unit = 1mm, or 1 acad unit = 1 ft.
Message 7 of 8
jayhar
You can change Scale factor in dimension style or selecting dimension go to properties below primary units Dim scale linear see the video.
  https://autode.sk/2ynbYvv
or
https://knowledge.autodesk.com/community/screencast/18000cbb-dae5-46f8-938a-18ea9bb7978e
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 8 of 8
dgorsman
If you take a look at the circled label on the dialog screen shot, it says:
"Units to scale inserted content" (emphasis on inserted)
It means what it says - if the inserted content (i.e. blocks) has units, rescale it by the appropriate factor to show in meters.
