AutoCAD Forum
how do you dim up now
3 REPLIES 3
Robertacadndrew
299 Views, 3 Replies
is there a way to update dimension.  the dim update command seems to be eliminated.  for example you change the dimscale how to I update the existing dimensions?
Thanks in advance!!
A
Thanks so much,
Mechanical Designer
Rob Baxley
3 REPLIES 3
Read this thread
and this online help
Paul Li
IT Specialist
@The Office
pendean
in reply to: Robertacadndrew
@Robertacadndrew  The button (and the commandname to activate it) have been over here for some time how, hope this helps
thanks!!
Thanks so much,
Mechanical Designer
Rob Baxley
Forma Design Contest
