is there a way to update dimension. the dim update command seems to be eliminated. for example you change the dimscale how to I update the existing dimensions?
Thanks in advance!!
A
Solved by pendean. Go to Solution.
@Robertacadndrew The button (and the commandname to activate it) have been over here for some time how, hope this helps
