This is what my screen looks like
Help says to click view tab>Coordinates Panel
But there is no coordinates panel showing on the view tab
Solved by ВeekeeCZ. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
>> How do I get my UCS to line up with the screen?
Not sure to understand you correct, it might be
- alfred -
Thank you.
_PLAN option Current got the orientation.
Right clicking helped me make the View tab visible.
Thanks again.
Huck
_PLAN worked in several layout tabs, but in one of the tabs I get the message:
** Command only valid in Model space **
What could be going on?
