AutoCAD Forum
How do I get my UCS to line up with the screen?
4 REPLIES 4
779 Views, 4 Replies
This is what my screen looks like
Help says to click view tab>Coordinates Panel
But there is no coordinates panel showing on the view tab
4 REPLIES 4
Alfred.NESWADBA
Not sure to understand you correct, it might be
  • _UCS and option _VIEW ==> this creates a UCS wich is aligned to the current view
  • _PLAN and option _UCS ==> this rotates the display so that the current UCS-X direction is parallel to the screenborder.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
ВeekeeCZ
It's hidden. Right click...
in reply to: ВeekeeCZ
Thank you.
_PLAN option Current got the orientation.
Right clicking helped me make the View tab visible.
Thanks again.
Huck
in reply to: Alfred.NESWADBA
_PLAN worked in several layout tabs, but in one of the tabs I get the message:
** Command only valid in Model space **
What could be going on?
Technology Administrators
AutoCAD Beta
