AutoCAD Forum
How can I turn on all layers at the same time?
5 REPLIES 5
40330 Views, 5 Replies
Is there a way to turn all the layers on with one click?
5 REPLIES 5
Patchy
Make a icon for LAYON
imadHabash
Command: -LA
Current layer: "LOGO"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: on
Enter name list of layer(s) to turn on: *
the above command ( -LA --> ON --> * ) will turn ON all layers by typing * (star) and as shown. if do you want to make it as one typing command . you can record an action recorder and save previous command with a unique name. >> Click <<
NOTE : as mentioned below @gotphish001 he is right just click the button Layon .
Imad Habash
gotphish001
I have autocad architecture open right now but I assume it's the same. On the home ribbon if you pull down the layer drop down there are buttons across the top of the pull down. The first one is turn on all layers.Capture.JPG
Nick DiPietro
Cad Manager/Monkey
in reply to: imadHabash
Thank you, this worked! Appreciate your response
in reply to: gotphish001
Thank you for your time!
Forma Design Contest
AutoCAD Beta
