Is there a way to turn all the layers on with one click?
Solved by gotphish001. Go to Solution.
Solved by imadHabash. Go to Solution.
Command: -LA
Current layer: "LOGO"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: on
Enter name list of layer(s) to turn on: *
the above command ( -LA --> ON --> * ) will turn ON all layers by typing * (star) and as shown. if do you want to make it as one typing command . you can record an action recorder and save previous command with a unique name. >> Click <<
NOTE : as mentioned below @gotphish001 he is right just click the button Layon .
Imad Habash
I have autocad architecture open right now but I assume it's the same. On the home ribbon if you pull down the layer drop down there are buttons across the top of the pull down. The first one is turn on all layers.
Nick DiPietro
Cad Manager/Monkey
