I use to select text and then I was able to change the justification or size in the properties box, but I noticed today that it doesn't seem to be working.
I haven't tried this in a few months so I am not sure when it stopped.
I have read a few posts that seem to think that it is caused by A360?
I really don't like the idea of uninstalling and reinstalling autocad.
I'm using AutoCAD 2015.
Please help.
Steve
does the property window ignore every type of selected object or just text? So what happens when you select a line ... what does the property window show you?
One idea about property window ... we have to differentiate between "property window" and "quick properties". To identify what you are referring to exactly please select a text and then create a screenshot so we can see which window(s) you have visible and what you see in your property window.
- alfred -
>> but I noticed today that it doesn't seem to be working. <<
what exactly the error you've got ? would you please show us an image for your issue ?
regards,
Imad Habash
does that happen only for text-objects or also for any other types of selected geometry like line or so?
Did you uninstall A360 after you had installed AutoCAD?
- alfred -
Same thing on lines. I don't remember uninstalling A360, it is a pretty old version of Autocad 2014, not sure if it was before A360?
Steve
Yep, that statement was important "...AutoCAD 2014"!
First you mentioned AutoCAD 2015, and for AutoCAD 2015 I would not know such a behavior, but for AutoCAD 2014 there was an issue when uninstalling A360 that the property window did not work anymore.
Look to your Windows control panel ==> programs and functions if A360 is installed or not. From older threads the solution was then to uninstall AutoCAD and then reinstall AutoCAD (including A360).
But as you wrote that you did not uninstall it and current Windows updates do a lot to make software not working, maybe it was just a Windows update (Framework 4.7?) that was installed and so killed A360.
- alfred -
I don't see Autodesk A360 in my programs and features list, i do see microsoft .NET framework 4.6.1
Steve
then I would recommend to follow that article >>>click<<<.
Good luck, - alfred -
Thank you sir for your help. I have been hoping to not have to uninstall and reinstall. I set my AutoCAD up for work I do for a client and don't remember all the settings so I am afraid I am going to have to ask them for their settings again unless there are files I can save that have all my settings in them.
Thanks again,
Steve
