AutoCAD Forum
IMPORT GEO AERIAL IMAGE
5 REPLIES 5
429 Views, 5 Replies
HELLO GUYS,
I WANT GEO IMAGE TO BE ATTACHED TO MY DRAWING WHICH IS ASSIGNED WITH COORDINATE SYSTEMS.
I WANT TO LOOK FOR THE CLARITY WITH PLEX EARTH OF THE IMAGE, CAN ANYONE PROVIDE ME WITH THE SAME.
THANKS IN ADVANCE
5 REPLIES 5
imadHabash
i suggest to follow and read more about your issue here . >> Click <<
in reply to: imadHabash
I have completed the task using online map but I cannot send the soft file with the map attached in it also my file is very heavy and running like a snell.
TheCADnoob
A large enough raster image will slow any program.
check ETRANSMIT and see if it helps
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
CADnoob
Are you using plex earth?
No....But I want it by plex earth
Technology Administrators
