hi, I wanna ask about some type of pdf that doesn't import as a file with lines but only as a blank image rectangle. Other PDF files work fine and they transfer with all the lines and txt.
Would it be possible to get the .pdf that is causing the trouble in attachment. That way we can try it out for ourselves.
What version of AutoCAD are you using?
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
It sounds as if this one PDF contains only raster information and not vector data. This means that the PDF will be brought in as a PDF underlay. Is it possible to share the file?
