AutoCAD Forum
PDF file imported as an image that I can't work with
2 REPLIES 2
143 Views, 2 Replies
hi, I wanna ask about some type of pdf that doesn't import as a file with lines but only as a blank image rectangle. Other PDF files work fine and they transfer with all the lines and txt.
2 REPLIES 2
Michiel.Valcke
Would it be possible to get the .pdf that is causing the trouble in attachment. That way we can try it out for ourselves.
What version of AutoCAD are you using?
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
It sounds as if this one PDF contains only raster information and not vector data. This means that the PDF will be brought in as a PDF underlay. Is it possible to share the file?
John Vellek
Technology Administrators
