@florisvanburen wrote:Hatches aren't visible in blocks.
What do I wrong. See image for block. See drawing for the unbisible hatch of the block. Click on the block to see the hatch exist.
Edit your block. Change the hatch in the block to a solid fill. Save and close the block. Upon doing so I was able to have the hatch show up in your dwg.
You units are way up there. Any time you get into numbers that large the voodoo of computing takes over.
There are far to many anges that are trying to be displayed in the hatch.
if you have to keep things in the dimensions that they are, you can change the scale to reduce the number of angles being created
once that is done your hatch is visible
CADnoob
