Доброго времени суток!
Программа AutoCad 2015 не запускается, ошибок во время запуска не появляется.
Solved by Emmsleys. Go to Solution.
Hi @Anonymous,
If it is okay with you I am going to respond in English.
I believe your issue is that you are receiving an error when starting AutoCAD.
Solutions to common startup errors for AutoCAD®-based products are listed below. Try applying these first and then review additional instructions if the problem persists.
Also feel free to post back in whatever language you feel comfortable with should you have any other questions I'll try my best to help.
