AutoCAD Forum
From option in Move command does not work with small numbers
6 REPLIES 6
1376 Views, 6 Replies
I am using ACAD 2017. When using the "from" option in move or copy commands with small numbers/fractions (0.1 or 0.01 units) the object does not move at all or does snap to the "target point" for the direction.
Any suggestions? Thx in advance
6 REPLIES 6
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Can you please press <F2> (to see more lines of command-line history) after you completed your copy or move sequence and show us a screenshot, so we see when you used _FROM ...?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Here is a copy of the command line:
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Command: _.erase 1 found
Command: PL PLINE
Specify start point:
Current line-width is 0.000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: *Cancel*
Command: m MOVE 1 found
Specify base point or [Displacement] <Displacement>:
Specify second point or <use first point as displacement>: _from Base point: <Offset>: .01
Unfortunately it does move the object to the base point without offset...
Alfred.NESWADBA
you don't need _FROM in that case, as you only define a distance and a direction to move an object ... in that case you can use any base point, then show a direction with the cursor and enter the distance, in your case 0.01.
Have you moved your cursor far away from the object? If not it might again find an object snap to your polyline (and so start point and destination point for the move vector stays the same).
- alfred -
Alfred NESWADBA
Thank you for your replies, Alfred.
Unfortunately this error appears quite randomly.
I just did the same operation again and instead of displacing the object 0.01 units ACAD decided to displace 0.001 units:
Command: CP COPY 46 found
Current settings: Copy mode = Single
Specify base point or [Displacement/mOde/Multiple] <Displacement>:
Specify second point or [Array] <use first point as displacement>:
Command: *Cancel*
Command: CP COPY 2 found
Specify second point or [Array] <use first point as displacement>: _from Base point: <Offset>: .01
Command: DI DIST
Specify first point:
Specify second point or [Multiple points]:
Distance = 0.001, Angle in XY Plane = 180, Angle from XY Plane = 0
Delta X = -0.001, Delta Y = 0.000, Delta Z = 0.000
Command: DIST
I mesured the displacement afterwards...
It looks to me like autocad decides to round off numbers at random in this operation. Sometimes it jumps to 0.02 instead of 0.015 and similar. Since this is a very frequent tool in my drafting it is unfortunate to not be able to trust ACAD on moving the object to an exact number.
Turn off running osnap
Alfred.NESWADBA
I would say "close to impossible" as long as you are working 2D (no 3D objects in the drawing and no Z-values exist <> 0.0) and as long as you are not working in layout ...
Can you show a screencast (>>>click<<<) + upload the drawing you are working with?
That might happen with SNAP on.
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
