en respuesta a: Alfred.NESWADBA
Here is a copy of the command line:
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Command: _.erase 1 found
Command: PL PLINE
Specify start point:
Current line-width is 0.000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: *Cancel*
Command: m MOVE 1 found
Specify base point or [Displacement] <Displacement>:
Specify second point or <use first point as displacement>: _from Base point: <Offset>: .01
Unfortunately it does move the object to the base point without offset...
