Hello Friends,
I exported my sheet from Revit to Autocad, It happened well as I have to add some colors in wall and at the site. I did this as Revit doesn't allow this feature.
I am trying to convert that dwg file to pdf, but after following the steps I cannot convert it in A1 size as The image in pdf file looks too small that no one can see it properly after zooming.
Can anyone help me why I am having such issue? It's urgent I have to send that pdf before Monday!
Attaching the pdf that I am getting!
Create a layout and run _PLOT using "DWG to PDF.pc3" as driver. That gives you full control about page sizes for your PDF (which can't be defined using _EXPORTPDF).
At least you have some objects far away from each other, so that's the reason why they are so small ... to fit on a PDF page.
- alfred -
did my first suggestion work?
>> I need my pdf in black lines and text only... No any other colour
Use first command _SETBYLAYER to convert all properties to bylayer (you can use option _SETTINGS to only convert colors to "bylayer").
Within the layermanager you can then assign color 7 (black/white), so ready to be printed in black.
If something is not converted then we need the drawing to see which objects are not working with that suggestion.
- alfred -
PS: please create a new thread for new question as e.g. this question now does not have anything to do with the original title, so future readers would not find these questions/suggestions.
