FATAL ERRORS when closing AC17 in Windows 7
不适用
773 次查看
3 条回复
1 条消息(共 4 条)
不适用
Dear Team.
Ich installed Windows 7.
There i installed AC17 Deutsch (German). > AutoCAD_2017_German_Win_64bit_dlm_001_002.sfx
Then i installed the english language pack > AutoCAD_2017_English_LP_Win_64bit_dlm.sfx
Also the AC17-Update to AC17.1.1 > AutoCAD_2017.1.1_Update_64bit.exe
And also the AC17 service pack 1 > AutoCAD 2017 SP1 (64-Bit )
english and german Version starts normal.
BUT both of them always ends with FATAL ERRORS (when i quit the english and german application AC17)
What could i do for close AC17 without FATAL ERRORS`?
Kind regards
Se Ur
0 个赞
已接受的解答 (2)
774 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
Alfred.NESWADBA
已接受的解答
welcome @Anonymous.autodesk.com!
Did you see the crash also before you installed the English language pack?
Also important: do you get the crash after the last dwg was closed or do you see the crash while any documents are open in AutoCAD?
I would start with:
create a new Windows user account, give that user admin permissions, login with that account, disconnect your workstation from network, disable antivirus software ... and now try AutoCAD again ...
- alfred -
PS: there is also a German AutoCAD forum >>>there<<<
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
3 条消息(共 4 条)
不适用
hello,
yes thanx alot!
i add a parameter to
C:\Program Files\Autodesk\AutoCAD 2017\acad.exe /nohardware /product ACAD /language "en-US"
/nohardware
was the point and all i finishing without FATAL ERRORS.
Bye & kind regards
4 条消息(共 4 条)
Emmsleys
已接受的解答
Hi @Anonymous,
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks.
Sarah Emmsley
Technical Support Specialist
