Object Outlines of different color then the object
mohsin_160
mohsin_160
I need a solution for;
Consider a 3D Box and the layer color is Blue. I need to have the outline of the same Box in yellow. Is there any solution for it to have an object with 02 different colors in a single layer?
Regards
Alfred.NESWADBA
You can use <CTRL><Click_onto_the_edge> to get edges of the box selected and - using property window - assign a different color.
But be warned, you are creating a structure which is not easy to handle, e.g. selecting all yellow edges and change them to green is far away from a 2-click job (compared to changing layer colors and so get the objects to the new color setting).
If you can describe what your plan is, maybe we can find a better solution or workaround for the job!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
GrantsPirate
Are you talking about while the 3D box is in a shaded visual style, like Realistic, etc?  And would this be per object or just for everything in the model, or...?
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
mohsin_160
Actually I am trying to make something like this...
Regards
Alfred.NESWADBA
Well, have you tried my suggestion?
From what I understand you can do what you are looking for... Does it work for you?
To the alternative:
It depends on how you proceed. If you need a rendering of that object then I would not know how you get edges rendered differently without using tricks (like a 3D-construction of the edges like small cylinders ... or using other products like 3DS-Max which can do that in the material/shader definitions).
If you can live with just modifying a style and all objects can have the same edge color you might change the visual style, that can be used on display and for plotting.
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
Hi again,
additional setting: changing visual style to show edges, color set to "byLayer", assign the object a material (in my case "LED red off") and set the geometry objects on different layers (and so different layer colors).
That's the result:
- alfred -
Alfred NESWADBA
