.mwf file too large (please help)
I have some troubles with a .wmf export.
When i create the .wmf file, it is too large to be operated in my surveillance software.
They aren't xref or other problematic items.
Could you help me?
Thanks a lot.
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Please, can you give us a bit more details?
What is large? Is it a file-size or a number of vectors, or ...?
Which software product is your "surveillance software" and what is the maximum size of ?? that software can import.
Is it really true that you exchange CAD data by WMF? Isn't there a more accurate file type possible to send your geometry?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 Does your surveillance software accept PNG format? That might reduce the size for you. Here is an article on plotting raster formats but you can even use the Windows Snipping tool to grab your AutoCAD drawing screen and it will save as PNG by default.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
