AutoCAD Forum
Fatal error Autocad 2011
8 REPLIES 8
Message 1 of 9
671 Views, 8 Replies
Autocad is experiencing error when initializing: "FATAL ERROR: Unhandled c0000094h Exception at 65a99e7fh".
8 REPLIES 8
Message 2 of 9
rkmcswain
When did this start happening?
What happened to your PC just before that date/time?
Windows updates? Rollback to a date when it was working okay.
Log into the PC as a different user? Does it still happen to this other user?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 9
in reply to: rkmcswain
An error occurs in an expecific profile. Windows with new installation. It happened first in all profiles and, after applying Update 2 that is available on the site, only an expecifico profile. I re-created the profile and error persists. I performed the test with the same user in different machine and error persists.
Message 4 of 9
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 What OS are you running this in? Windows 7?
John Vellek
Message 5 of 9
in reply to: john.vellek
Thank you!!
Yes, I'm using Windows 7.
Message 6 of 9
john.vellek
HI @Anonymous,
What is unique about this one profile?  I assume you are referring to an AutoCAD profile and not a Windows profile.
Do you have any add-ins or customizations?
John Vellek
Message 7 of 9
I mean the Windows profile. We do not have any customizations. We have already tested the same user profile on another computer and it worked.
Message 8 of 9
john.vellek
Hi @Anonymous,
Try removing the profile from this one machine and then put it back on fresh.  This sounds like a Windows issue where the profile has become corrupted on the one computer.  Are you using Roaming profiles?
John Vellek
Message 9 of 9
We've tried this solution but it was inefficient. We do not use roaming profile.
Forma Design Contest
