Autocad is experiencing error when initializing: "FATAL ERROR: Unhandled c0000094h Exception at 65a99e7fh".
When did this start happening?
What happened to your PC just before that date/time?
Windows updates? Rollback to a date when it was working okay.
Log into the PC as a different user? Does it still happen to this other user?
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
What OS are you running this in? Windows 7?
Hi @Anonymous,
Thank you!!
Yes, I'm using Windows 7.
Thank you!!
HI @Anonymous,
What is unique about this one profile? I assume you are referring to an AutoCAD profile and not a Windows profile.
Do you have any add-ins or customizations?
HI @Anonymous,
I mean the Windows profile. We do not have any customizations. We have already tested the same user profile on another computer and it worked.
Hi @Anonymous,
Try removing the profile from this one machine and then put it back on fresh. This sounds like a Windows issue where the profile has become corrupted on the one computer. Are you using Roaming profiles?
Hi @Anonymous,
We've tried this solution but it was inefficient. We do not use roaming profile.
