AutoCAD Forum
Failure to export license
3 REPLIES 3
287 Views, 3 Replies
I've recently upgraded a Windows 7 32bit machine to 64 bit.
when i wanted to export the license and bring it to my new 64 bit machine, it returned with "Code 40" Failed to export license
I see my serial and ID number, but the utility keeps failing.
How can I successfully fix this issue and resume proper AutoCad 2015 work?
Thank you!
3 REPLIES 3
wispoxy
Error Code: 40
Lost license handler callback function is not registered
You'll have to speak to AutoDESK support. Chat with them.
Visit http://knowledge.autodesk.com/contactus
  1. Select what we can help you with
  2. Select appropriate subtopics from the pull-down menus
  3. Select “I Still Need Help” and the option for Chat will appear
  4. Click "Chat" button and you will be taken to the Live Chat
pendean
wispoxy
in reply to: pendean
It's annoying that so many errors require AutoDESK support.
Forma Design Contest
AutoCAD Beta
