Hello
I have problem with my Autocad 2015. When i try to export it to PDF then the margine is cut of on the right hand side of the page. I will attach my documents here so you can see it. Can someone tell me what I can do to fix this?
Kind Regards
I don't find a laoyut in your drawing, also no plot-settings saved for your modelspace, so whatever I do to plot to PDF may have different settings compared to yours.
So I would suggest you create layouts for each page, within the layout you can adjust the plot settings (including the plot-offset) and use then PLOT or PUBLISH to create your PDF's.
Good luck, - alfred -
