AutoCAD Forum
Export to PDF margins cut on the right side
2 REPLIES 2
1180 Views, 2 Replies
Hello
I have problem with my Autocad 2015. When i try to export it to PDF then the margine is cut of on the right hand side of the page.  I will attach my documents here so you can see it. Can someone tell me what I can do to fix this?
Kind Regards
2 REPLIES 2
Alfred.NESWADBA
I don't find a laoyut in your drawing, also no plot-settings saved for your modelspace, so whatever I do to plot to PDF may have different settings compared to yours.
So I would suggest you create layouts for each page, within the layout you can adjust the plot settings (including the plot-offset) and use then PLOT or PUBLISH to create your PDF's.
Good luck, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
pendean
PDF files have wider margins that paper plots: you need to adjust your drawing to reflect that reality. There i no fix in AutoCAD for it.
Consider using PLOT command to control your PDF output better than "export".
Forma Design Contest
