- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Yesterday I was cruising along as normal when all of the sudden my escape key stopped working. I believe it happened after I accidentally loaded the dbconnection manager or something similar but not sure. When I envoke a command, the escape key does nothing. When I select something and hit the escape key, it doesn't deselect everything. I know it's not my keyboard because I'm using a laptop and both the attached keyboard and the keyboard on the laptop function the same in that the escape key doesn't work. I also have a Logitech Performance MX with a button set as the escape command and that doesn't work. When I type in cancel or ^c^c, the response is "unknown command". I have searched the discussion boards and have given up and am hoping that someone knows how to fix this in a jiffy. Thanks in advance for your help.
