Escape Key and Cancel Command not working
Message 1 of 49
Yesterday I was cruising along as normal when all of the sudden my escape key stopped working.  I believe it happened after I accidentally loaded the dbconnection manager or something similar but not sure.  When I envoke a command, the escape key does nothing.  When I select something and hit the escape key, it doesn't deselect everything.  I know it's not my keyboard because I'm using a laptop and both the attached keyboard and the keyboard on the laptop function the same in that the escape key doesn't work.  I also have a Logitech Performance MX with a button set as the escape command and that doesn't work.  When I type in cancel or ^c^c, the response is "unknown command".  I have searched the discussion boards and have given up and am hoping that someone knows how to fix this in a jiffy.  Thanks in advance for your help.
Replies (48)
Message 41 of 49
Mine started working with the combination of shift key though its not a permanent solution..
Message 42 of 49
Hello, I just want to let everyone know that I have also run into this problem, some other programs may be locking the action of the ESC key, you may still be able to cancel a command by pressing Shift+ESC at the same time. In any case, simply close the other programs you are running one at a time to find the culprit. Some have mentioned Adobe Photoshop, I personally found the issue to be another app. I hope this helps someone before they do something complicated.
Message 43 of 49
I was having this problem with AutoCAD 2019. I set my PICKFIRST to 0, picked a few things and escaped, which did deselect them. Then I set it back to 1, and escape is working again.
Message 44 of 49
Kindly Re-install the ATI video driver software. then try it.
Message 45 of 49
Yes!  This is why my Esc key won't work and it's impossible to exit a command without hitting the Save button.  Closed Photoshop and it works fine again.
Message 46 of 49
Sezal
I had this problem, after reading some forums I got a simple solution. I suggest closing any adobe's program you have open while working with inventor before installing a weird-unknown software, re-installing inventor, or even worse, Windows.
The adobe's programs create this bug in inventor and maybe Autocad and revit (Not sure). I had opened acrobat, but for others was photoshop.
Good luck.
Message 47 of 49
Hi All
My solution is similar to the Photoshop/Adobe issue but it was Omron Programmer "stealing" the Esc Key. Can't run both software at the same time.
Message 48 of 49
ehaskin5
Observer
Observer
My ESC key is not working I am running windows 10/11 with paralles. I have been running AutoCad on this viritual machine for months and have never had this issue before.
What I have tried so far:
-I don't have photoshop installed on my computer
-I have uninstalled and reinstalled AutoCAD
-I have uninstalled and reinstalled my keyboard
-I have reinstalled default setting on CAD
-REGEN/AUDIT/PURGE Drawings
-CUI command and set F1 to function as ESC (not working)
Message 49 of 49
JBrass
@ehaskin5 I had this problem and came here for the solution.  It was so simple in my case, after trying lots of the suggested solutions.  I shut down, did a reboot and it worked again.  I was embarrassed at such a simple solution.  I hope it's this easy for you.  If not, sorry, I don't know but I've never had the problem again, touch wood.
