Escape Key and Cancel Command not working
Message 1 of 49
Yesterday I was cruising along as normal when all of the sudden my escape key stopped working.  I believe it happened after I accidentally loaded the dbconnection manager or something similar but not sure.  When I envoke a command, the escape key does nothing.  When I select something and hit the escape key, it doesn't deselect everything.  I know it's not my keyboard because I'm using a laptop and both the attached keyboard and the keyboard on the laptop function the same in that the escape key doesn't work.  I also have a Logitech Performance MX with a button set as the escape command and that doesn't work.  When I type in cancel or ^c^c, the response is "unknown command".  I have searched the discussion boards and have given up and am hoping that someone knows how to fix this in a jiffy.  Thanks in advance for your help.
Replies (48)
Message 21 of 49
Quit Photoshop!! My dear god, thank you for that! I was going insane!!
Message 22 of 49
I'm having this problem now too.  No escape key function...all of a sudden.  Has anyone figured it out?  Also, why is the escape key nowhere to be found in the help menu?  It gave me some useless article on something called "is_cancel" when I searched "esc key"  or "escape key".  Does anyone know how to get my escape key functioning again???
Message 23 of 49
Dear You Have to close photoshop application and then it will work
Thanks and Best Regards
A.M.Yafai
Message 24 of 49
A.M.Yafai
Message 25 of 49
usu2002...THANK YOU!
This was also driving me crazy and Photoshop was the culprit. I don't think I'd have ever made that connection.
Message 26 of 49
Message 27 of 49
Also had this problem, for people doing PLC programming make sure any Omron CX-Designer Programs are closed as well. It appears to have the same effect as photoshop that others had described.
Message 28 of 49
Thank you SO much. This was driving me absolutely crazy. Indeed, the second I closed my photoshop the esc worked again. So relieving 🙂
Message 29 of 49
I also had this issue, however no Photoshop installed.  Based on your resolution though I discovered it was due to Teamviewer being connected to a remote computer.  I closed Teamviewer and bingo.
Message 30 of 49
OMG! You are my hero! You are my knight in shining amour. So easy but so many hours wasted. Should have started here! THANK YOU!!!!!!!!!
Message 31 of 49
Your welcome! I never imagined this situation would come up after this many years. I’m glad it is helping others and saving time.
Message 32 of 49
Worked for me,  I had problems with my ESC button aswel.  Closed photoshop, ESC button works fine again.
Message 33 of 49
Thanks!!!!
Message 34 of 49
Your welcome!
Message 35 of 49
JBrass
My escape key stopped working suddenly in Revit 2016, but it still works in AutoCad 2015.  I do not have Photoshop or any of the other programs listed in people's questions, loaded on my computer.  It's Windows and I'm using Windows 7 Professional for years now.
Any ideas what could be causing this?  I'm not happy...
Message 36 of 49
Another program is blocking its use close your other programs and see if that fixes it.
Message 37 of 49
JBrass
thanks, I only had Outlook and Chrome open to write this post, but a shut down and restart worked.  Why do I never think of that first?  ;o)
Message 38 of 49
happened to me too..as soon as I closed PhotoShop, esc work right away. Using AutoCad Architecture 2016. bizarre..
Message 39 of 49
albionpjl
 This happens to me all the time. I'll be working and suddenly escape, cancel. save, change layer, select, stop working.
It only started doing this with C3d 2017.
I usually have to close C3d down completely and restart it in order to regain the commands. Luckily, I usually fond out that save DID work, it just didn't report that it had done anything.
The suggested solutions don't help because I do not have Photoshop or any of the other listed software.
It's like the Cad window stops refreshing.
Message 40 of 49
Same thing happened to me with InDesign open. Thanks for the great catch...it was driving me mad!
