AutoCAD Forum
dwg to pdf error
6 REPLIES 6
julija_puckova
425 Views, 6 Replies
dwg to pdf error
when I import a dwg file into PDF, everything crashes immediately (on any device), after which a table appears - send the report. 😥
6 REPLIES 6
paullimapa
in reply to: julija_puckova
I assume you're referring to Exporting a dwg to pdf or Plot a dwg to pdf?
Paul Li
IT Specialist
@The Office
julija_puckova
in reply to: paullimapa
Plot a dwg to pdf
paullimapa
does this happen to only one dwg or all dwg?
what version of autocad?
enter About command, do a screen shot and share that here
Paul Li
IT Specialist
@The Office
julija_puckova
It only happens with this file. Education version 2024 .
paullimapa
you are running an older version of 2024
login to your account and download latest
should be U.152.0.0 2024.1.2
Paul Li
IT Specialist
@The Office
pendean
@julija_puckova wrote:
It only happens with this file....
Then you need to fix that one single problem file. Here is a long list of ways to do that, start at the top and work down the list
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-File-Corru...
If that did not help, start here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Crash-when-plottin...
Forma Design Contest
AutoCAD Beta
