when I import a dwg file into PDF, everything crashes immediately (on any device), after which a table appears - send the report. 😥
Solved by pendean. Go to Solution.
Solved by paullimapa. Go to Solution.
I assume you're referring to Exporting a dwg to pdf or Plot a dwg to pdf?
does this happen to only one dwg or all dwg?
what version of autocad?
enter About command, do a screen shot and share that here
It only happens with this file. Education version 2024 .
you are running an older version of 2024
login to your account and download latest
should be U.152.0.0 2024.1.2
@julija_puckova wrote:
It only happens with this file....
Then you need to fix that one single problem file. Here is a long list of ways to do that, start at the top and work down the list
If that did not help, start here
