AutoCAD Forum
PDF quality probleme
12 REPLIES 12
Message 1 of 13
raphael.taiebTDAJY
503 Views, 12 Replies
Hello everyone
I have big problems exporting pdf from autocad 2024. The quality of the export is very poor and my hatchings and curves are very pixelated.
I followed several steps (4800 dpi, high quality, lines merges, ...) but nothing to do.
I have this problem on several files and it's the same for the people I send them to, or when I print.
I hope one of you has an answer.
Thanks in advance
12 REPLIES 12
Message 2 of 13
What if you use the Plot command and then for Printer/Plotter select DWG To PDF.pc3 to create your PDF?
Paul Li
IT Specialist
@The Office
Message 3 of 13
@raphael.taiebTDAJY You have SHADEMODE set to something other than 2D, set to do a swiggle-line, and that's why your results look like that
Message 4 of 13
I use DWG TO PDF.pc3 with a custom CTB and correct scaling of my drawings.
Message 5 of 13
I use Shademode in 2D wired mode
Message 6 of 13
change shade plot to: As Displayed
and make sure VSCurrent is set to 2dwireframe
Paul Li
IT Specialist
@The Office
Message 7 of 13
Share your DWG file here if the tips above do not fix it for you.
Message 8 of 13
Thanks for your help, but I still can't do it. I'll share the file with you.
The quality is down to 600 dpi (which is normally sufficient) for inconclusive tests.
Message 9 of 13
Are you plotting from modelspace
Or paperspace (and a very custom very small postcard page size and a very small viewport plot scale that is going to look horribly wiggly when you zoom in very close)
Message 10 of 13
I draw graphics from the model-space and export to a custom paperspace 130x250mm (maybe that's where the problem comes from).
Message 11 of 13
Message 12 of 13
... export to a custom paperspace 130x250mm (maybe that's where the problem comes from).
yes, it appears you may have a lot of scaling issues in this DWG file (a 1,52mm wide staircase in modelspace?), and trying to prints such a large model on a half-letter page is never going to give you a crisp line in PDF, it does not work like that
Looks like this DWG file is supposed to be in meters but it is not, its in mm. A separate issue that's not going to change the plot to a half-page reality sadly.
Message 13 of 13
Thanks a lot for your help, I don't understand why the file is in mm but ok.
I have several files with this same problem, do you have an idea so that it doesn't happen to me in the future?
Forma Design Contest
AutoCAD Beta
