AutoCAD Forum
Drawing in perspective
6 REPLIES 6
BrithneyMoralesJaimes
698 Views, 6 Replies
Hello! I have an issue with my drawing. I design my floor plans on 2D but when I change the view all the lines go crazy. Do you know why this happens? Thank you so much.
6 REPLIES 6
HI BMJ94
In looking at your post I am suspect of some graphic card settings. Could you try to turn off line smoothing and maybe even Hardware Acceleration to see if eliminates the problem for you?
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
in reply to: BrithneyMoralesJaimes
It looks like the topo's you brought in came in with a Z elevation way above zero.  In the topdown method of drawing, you probably snapped to lines that were way up in the air.  You could try using FLATTEN to get everything back to a zero elevation if that's your goal.
Have you tried command FLATTEN?
i recently had a drawing that i had to correct a similar issue on. Flatten didnt work for me but luckily the geometry was realtivley simple. I just selected everything and changed all the Z values to 0.
CADnoob
Hi john.vellek. I have them already off, so I turned them on and then off again; but nothing changes.
Hi BMJ94, If the problem is not a graphics issue then as per the other posts, it is likely that some of your entities have an erroneous Z value (height). Check out the prior posts to correct this. Flatten works pretty well but if the drawing is simple you might select all the entities and enter a new Z value as per @TheCADnoob's suggestion.
John Vellek
Forma Design Contest
AutoCAD Beta
