all of a sudden most of the autocad commands stopped working. any one no why this is happening?
Solved by Alfred.NESWADBA. Go to Solution.
welcome @Anonymous.autodesk.com!
Sorry, no, because we don't know what happens when you start command _LOFT
Type in command _LOFT, then press <ENTER> and follow the command as long as possible ... and let us know what AutoCAD tells you in the command line, That is what we need to (hopefully) know what happens on your system.
BTW: you have tried to restart AutoCAD and if that does not work to restart your workstation and you tried the command in a new drawing too?
- alfred -
alfred, thank for the response however "loft" command says select cross section in lofting order. this doesn't sound right
Why not, that is correct and ok, >>>click<<<.
What are you expecting?
- alfred -
Hello dwadams, and welcome to the Forums!
Did any of Alfred's posts get your problem resolved? If so, please hit the Accept as Solution button so that more community members can profit from the solution.
@Anonymous wrote:alfred, thank for the response however "loft" command says select cross section in lofting order. this doesn't sound right
It's been like that since I can remember. Are you thinking of EXTRUDE or SWEEP?
@Anonymous
Did any of the posts get your question answered? If so, please hit the Accept as Solution button so that more community members can profit from the solution.
If not, please post back and I (and the Community) will be happy to continue assisting you!
